Help: Civic eg si with b20z swap blower no Heat~
hi guys, i just did a bone stock B20Z motor with b18b IM in my civic eg HB and for some odd reason the car overheats, then the blower will only blow hot air when i have my foot on throttle. can someone please explain the situation i am in?
Did i hook the coolant hoses wrong or something?
i could locate if there are any leaks from the hoses but can't explain why the heat only works when i have throttle. A/C works fine by the way.
thanks guys~
thanks guys~
Re: Help: Civic eg si with b20z swap blower no Heat~
i have just upgraded the radiator to aluminum one's and a lower temperature thermostat (71C)
Both upper/lower radiator hoses are hot at idle, fan turns on but still no heat whats going on guys? i really need help on this...
i googled it and couldnt' find any hoses diagram
can someone please help me out with visual pix?
thanks a lot guys~~~
hondaparts diagram are partially pix not the full diagram
thanks
wow
thats awesome man~ thank you so so much for the diagram
oh ~ i did leave the cap off and let the engine running for 40mins or so(fan kicked in twice while idle), would that be enough? or i still need to bleed from the thermostats bleed valve?
doubleoazn03
11-26-2012 12:20 PM
jayeghatch
12
08-25-2012 02:26 PM
jrvargas09
11-16-2011 08:00 AM
Louie_EM1
02-28-2004 09:39 PM
