d16y5 rebuild help
Re: d16y5 rebuild help
I guess picking up a factory service manual was out of the question? If you're asking this basic of a question, you NEED to buy yourself an FSM.
Absolute raw basics: Water pump, timing belt, tensioner, head gasket, valve cover gasket, spark plug grommets, valve stem seals, intake manifold gasket, exhaust manifold gasket. You'll also need a tube of HondaBond, as well as a tube of assembly lube.
Seriously, buy/borrow/download a factory service manual. It will make your life a LOT easier, and includes detailed pictures, torque specs of every bolt, as well as a list of tools at the beginning of the engine overhaul chapter that you'll need for the job.
If you loved me, you'd all sell me your magic cards to me today
Not worth any performance mods. Either rebuild it stock or get a different head.
The Chiltons and Haynes are $20 paper weights. Literally, I use them as paper weights to keep the FSM print-outs from blowing away. Never trust the torque specs in Chiltons or Haynes.
And yea, don't forget to prime the oil before first startup, and the break-in procedure.
