Heater core replacement help?
Old 08-10-2005, 08:40 PM
EG93si's Avatar
Default Heater core replacement help?
Heater core leaking, got a new core, but don't even know how to start to go about replacing it. its a 93 si with a sir-II swap if that would really matter. I did the swap all my self so im guessing i might have some skill required to do it. any help
a/c s all been removed too
Old 08-10-2005, 08:57 PM
dgrave's Avatar
Default Re: Heater core replacement help? (EG93si)
ok its no write up.... and i'm not the most technical.... but... you can start by taking out your whole dash.... there will be two cores.. .one for your ac and the heater core... the heater core is on the right (if you have ac i think)....not to bad once u get the whole dash off ( think there is two 8mm of each side of the dash...all the screws to get your center console out, and all the screws inside the vents, and all the screws at the cluster and behind the cluster)....and the steering wheel just lower it down... 2 bolts i think.... unplug the wiring for the heater core and plug your new one in...two hoses not sure whether its from the firewall or wat but... you can figure it out from there)...pretty basic ****... just a time consumer... good luck wit that... and anyone wit further tech information.. plz add...
mozzandherb
09-26-2005 01:17 PM
MugenHonda
12
09-25-2005 03:37 PM
lonefuzzy79
10-08-2003 12:37 PM
bbmoto
05-22-2002 12:13 AM
w00dy82
11-27-2001 04:43 AM
Quick Reply: Heater core replacement help?
