Question about reprogramming OEM remote on 98 civic
My friend has a 98 civic. His remote (factory) just stopped working and he even tried changing the battery but that didn't work. i heard that the remote might need to be reprogrammed and this does happen sometimes. how do i reprogram it or what are my options? is this something that the dealership have to take care of?
thanks in advance
thanks in advance
you can do it your self
with the key in the ign. turn the key on and push the lock button and than turn the key off. do this four times and it should program
key on button
key off
key on button
key off
key on button
key off
key on button
key off
key on button
key off
key on button
key off
key on button
key off
key on button
key off
NooB
Re: Question about reprogramming OEM remote on 98 civic (Razor)
youve been a member since 2001 and you dont know how to use the search.i searched and found it less than 10 seconds so try it not trying to be a dick but everybody gets on me about this so why dont everybody else try it it work
Re: Question about reprogramming OEM remote on 98 civic (BLACK EJ1)
ok i just found this out: my friend is running an aftermarket (pioneer) head unit in his car. does this have to do anything with his remote not working at all? how would he go about to reprogram the remote with an aftermarket headunit?
The factory head unit is the main source for the keyless operation in 96-98 civics.
Wont work if you have an aftermarket head unit I believe.
Re: Question about reprogramming OEM remote on 98 civic (Echo7847)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Echo7847 »</TD></TR><TR><TD CLASS="quote">The factory head unit is the main source for the keyless operation in 96-98 civics.
Wont work if you have an aftermarket head unit I believe.</TD></TR></TABLE>
hmm thats what i thought. do you think a dealership is able to reprogram the OEM remotes to work with an aftermarket head unit or is that out of the question?
when I put my radio in the interior light wouldn't come on with the door on and on the back of the factory radio it listed security so I did some searching and jumped the two wires together and that fixed my light problem.
Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLACK EJ1 »</TD></TR><TR><TD CLASS="quote">youve been a member since 2001 and you dont know how to use the search.i searched and found it less than 10 seconds so try it not trying to be a dick but everybody gets on me about this so why dont everybody else try it it work </TD></TR></TABLE>
owned
owned
Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Razor »</TD></TR><TR><TD CLASS="quote">
hmm thats what i thought. do you think a dealership is able to reprogram the OEM remotes to work with an aftermarket head unit or is that out of the question?</TD></TR></TABLE>
NO
the unit is in the "stereo" aka headunit!
NO
i've actually been wanting to try ripping open the stock head unit and see if i can just take out the components that are use for the OEM keyless entry/alarm. if i'm successfull, i'll probably do a write-up on it.
Moderator
Re: (MiMiK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MiMiK »</TD></TR><TR><TD CLASS="quote">i've actually been wanting to try ripping open the stock head unit and see if i can just take out the components that are use for the OEM keyless entry/alarm. if i'm successfull, i'll probably do a write-up on it.</TD></TR></TABLE>
you can't.....tried it already....back in 97 on a brand new 97 ex...
Maindrian
07-24-2006 12:52 PM
comeqkz
06-13-2006 03:40 AM
