headlight fogd
Darth ModerVader
Re: headlight fogd (EJacul8)
The most thorough way would be to remove the bulbs and leave the lamp in a dry location until all the moisture is gone. You can also accelerate the process using a hair dryer. Make sure that you check and repair any seals around the lamp which would be responsible for the initial water leakage.
edit: read it wrong my bad!
edit2:
https://honda-tech.com/zerothread?id=1152328
https://honda-tech.com/zerothread?id=524527
edit2:
Re: headlight fogd (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan »</TD></TR><TR><TD CLASS="quote"> Make sure that you check and repair any seals around the lamp which would be responsible for the initial water leakage.</TD></TR></TABLE>
maybe i should get a seal too then... P:JDM didnt have it on the lights
90gs
10-23-2005 11:55 PM
