GSR vs Type R
GSR vs Type R
here is the build i have an B18B block and pistons, i need to know which would be a better head to use , a B16 type R head or a GSR head?
Re: GSR vs Type R (cheesecheda)
we'll what is your bugdet? i would suggest building it na/boost before putting it in your car. my $.02 is that you buy a gsr head and do alot of port work to get it to flow alot better than stock. and saves you a little bit instead of going type- r
well i already have The Type R head on my B16 but now I'm swapping to the B18 and some wants to trade me heads, and i want to know which would be a head to use
Re: GSR vs Type R (nicks-eg6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nicks-eg6 »</TD></TR><TR><TD CLASS="quote">ok..... sale your blocks and buy a b20 block. if you build it right you can hit 200 whp na. </TD></TR></TABLE>
ok?.... Now that we know that, which head would result in more power on a B18 Block
FYI Type R heads and B16 heads are both cast from the same mold. They are both stamped pr3. The only difference between the two is the valve train and cams.
Re: (Spoolin93si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spoolin93si »</TD></TR><TR><TD CLASS="quote">FYI Type R heads and B16 heads are both cast from the same mold. They are both stamped pr3. The only difference between the two is the valve train and cams.</TD></TR></TABLE>
Along with the mild port that the ITR head has as well. That the b16 head does not have.
Re: (VTECth1s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cheesecheda »</TD></TR><TR><TD CLASS="quote">
ok?.... Now that we know that, which head would result in more power on a B18 Block</TD></TR></TABLE>
dumbass......if you already have a type r head why get rid of it
Re: (nicks-eg6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cheesecheda »</TD></TR><TR><TD CLASS="quote">well i already have The Type R head on my B16 but now I'm swapping to the B18 and some wants to trade me heads, and i want to know which would be a head to use</TD></TR></TABLE>
so you dont think im being a dick...... you said it yourself
b20_driven
10-14-2006 04:38 AM
B16Ek9
10
10-08-2003 01:04 PM
