gsr rears, brake pedal goes to the floor!
ok i need some help...i have a 95 civic hatch cx. swapped out my drums for gsr rears. bled the brakes with the help of a friend, and topped off the brake fluid.
when i drive the car i have to double pump it to brake. if i just press on the brakes once, it travels to the floor and the car does not stop. is this because i need to swap out my master cylinder to a 4040? or is this because i messed up bleeding the brakes somehow? can i get away with not upgrading the m/c for now?
ok one last question...will the mc off of a 2000 SI (without abs) bolt into my car or will some flaring/bending be involved?
thanks!
thanks!
Re: gsr rears, brake pedal goes to the floor! (kommon_sense)
sounds like you messed up bleeding the brakes.
Re: gsr rears, brake pedal goes to the floor! (Takeoff)
get a 91 civic ex master cylinder (bolts right up, same size as gsr) and bleed the brakes again.
Re: gsr rears, brake pedal goes to the floor! (Zer0DazE)
thanks for the help. everyones telling me i messed up so ill bleed them again.
Re: gsr rears, brake pedal goes to the floor! (Chiller514)
ok cool...pedal travel is a little further than before but im going to assume thats normal. ill deal with it till i get my larger mc and booster. ill throw the fronts on once i get that too.
can anyone tell me why my passenger rear "creaks" when i turn right? i double checked all the bolts and everything. everything looks fine to me...
92integraVTECgsr
25
07-09-2011 02:46 AM
DRKSol
09-14-2004 09:04 AM
