No Brakes!!! MIDAS says its the master cylinder..please read and help..
when i did my swap i removed the front brake lines and let them just sit there. well i bleed my brakes and the other day my brake pedal sank to the bottom. i had to pump it to get pressure. well now it is going all the way down but i stil have a little brake but not enought to stop me fully. i have a 94 ex with abs but i took the abs unit out. well i had midas bleed my brakes and they were fine for about two minutes. then they started to do it again. are they right is it the master cylinder and what can i do about it? and can i use my eg9 master cylinder and/or brake booster?
Re: No Brakes!!! MIDAS says its the master cylinder..please read and help.. (jh)
to check if its the master on your own, line lock all the rubber brake hoses, 4 total feel the pedal in the car if it still sinks its the master if it holds tight it may be something else.
92integraVTECgsr
10-29-2005 06:48 PM
