grinding noise
grinding noise
Today after i backed out of the driveway and started to drive to work, there was this horrible grinding noise comming from under the hood, so i stoped, and got out to look at it. i had my friend start up the car and the noise came back( a really bad grinding noise) and sounded like it was comming from the transmission. the wierd thing was after about 10 seconds of it it went away. the noise was there when the car was in neutral and when the clutch was pressed in
any ideas?
any ideas?
Re: grinding noise (civicmark)
so it's making "noises" while the clutch is pressed in or at the top?
if at the top it's the Input Shaft Bearing, if when it's pressed in TOB
but before anything just drain your trans fluid and put some honda mtf in there
Re: grinding noise (RACEPAK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RACEPAK »</TD></TR><TR><TD CLASS="quote">chack the axles
i once had symptoms like these and it was a broken axle. Car won't move with broken axles.</TD></TR></TABLE>
Emshhh
11
02-02-2005 11:10 PM
