grinding noise
Old 05-25-2004, 08:47 PM
civicmark's Avatar
Default grinding noise
Today after i backed out of the driveway and started to drive to work, there was this horrible grinding noise comming from under the hood, so i stoped, and got out to look at it. i had my friend start up the car and the noise came back( a really bad grinding noise) and sounded like it was comming from the transmission. the wierd thing was after about 10 seconds of it it went away. the noise was there when the car was in neutral and when the clutch was pressed in
any ideas?
Old 05-25-2004, 08:57 PM
ABK
ABK's Avatar
Default Re: grinding noise (civicmark)
throw out bearing? Check your tranny fluid. clutch maybe trying to take dump.
Old 05-25-2004, 08:59 PM
nY's FiNeSt's Avatar
so it's making "noises" while the clutch is pressed in or at the top?
if at the top it's the Input Shaft Bearing, if when it's pressed in TOB
but before anything just drain your trans fluid and put some honda mtf in there
Old 05-25-2004, 09:11 PM
RACEPAK's Avatar
chack the axles
i once had symptoms like these and it was a broken axle.
Old 05-25-2004, 09:14 PM
Inspector Gadget's Avatar
Default Re: grinding noise (RACEPAK)
I had the same problem with my vx tranny. It ended up being the throw out bearing.
Old 05-25-2004, 09:16 PM
5w20's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RACEPAK &raquo;</TD></TR><TR><TD CLASS="quote">chack the axles
i once had symptoms like these and it was a broken axle. Car won't move with broken axles.</TD></TR></TABLE>
tercelrcr
01-16-2012 06:50 PM
JDM215
08-30-2010 05:34 PM
Jdm_Eg686
15
10-09-2007 12:19 PM
4gnhatch
06-24-2005 06:53 PM
Emshhh
11
02-02-2005 11:10 PM
Quick Reply: grinding noise
