got a oill pressure gauge
ok i got a oil pressure guage for a 96 civic 2 dr ex and from my understanding the hose goes under the oil filter u got to take it off??? would u recomment a stell braided hose or keep the plastic white one?? does it matter?
Re: got a oill pressure gauge (95jeremie)
and a steel hose will give you a more accurate reading... for the most part it won't be that big of a difference unless the hose is like 10 feet long
Re: got a oill pressure gauge (cjmitthun)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cjmitthun »</TD></TR><TR><TD CLASS="quote">ok i got a oil pressure guage for a 96 civic 2 dr ex and from my understanding the hose goes under the oil filter u got to take it off??? would u recomment a stell braided hose or keep the plastic white one?? does it matter?</TD></TR></TABLE>
No, you don't take off the oil filter. You have to take out the oil pressure sensor and install a t-fitting in it's place. Then you need to screw the fitting for the gauge in one side of the t-fitting, and the oil pressure sensor in the other side.
-Shane
-Shane
Re: got a oill pressure gauge (nighttrain33)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nighttrain33 »</TD></TR><TR><TD CLASS="quote">No, you don't take off the oil filter. You have to take out the oil pressure sensor and install a t-fitting in it's place. Then you need to screw the fitting for the gage in one side of the t-fitting, and the oil pressure sensor in the other side.
-Shane</TD></TR></TABLE>
is it not possible to use a sandwich plate for the pressure reading???
i thought it was
i thought it was
yeah, you can use a sandwich (i like tuna)
If you do decide to use the pressure sender hole, you should attach a braided line from the block, with slack, and then T it later, so there is no stress on the fitting (they break). From there, just run it to the gauge or the e- sender. (since you said plastic Im assuming its a mechanical guage.....mm-mm hot oil being pumped into the interior)
Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg »</TD></TR><TR><TD CLASS="quote">yeah, you can use a sandwich (i like tuna)
If you do decide to use the pressure sender hole, you should use a line from the block, with slack, and then T it later, so there is no stree on the fitting (they break)</TD></TR></TABLE>
LOL i just got done with 2 yes 2 tuna sandwiches
i thought that you could
so where is cjmitthun...
trying to help ya out here lol
EDIT:
ok my bad he hit his 5 post for the day. till tomorrow
EDIT:
allright so use a braided hose pretty much...ya its electircal or something 2 wires for the ilum. and the hose....
you dont even have to plug the stock oil sensor back up, its useless.
your oil light will only come on if there is less then 5psi of oil in your motor, by that time its too late.
Unceasing Measure
Re: got a oill pressure gauge (VtecnTurbo)
Okay, enough with all the misinformation in this thread.
1.) yes, you can T off of the stock oil pressure sensor position, but you don't need to concern yourself with that annoyance if you don't want to.
2.) under your distributor, there are a couple hex-plugs that lead to the oil passage and the coolant jacket. If you unscrew the oil passage one you can mount your gauge pickup there and it will give you a fine reading for the life of the car.
I have an Autometer Ultralight mechanical oil pressure gauge and this is how I have mine set up. It's been working fine for two years now. Be careful when you screw the nylon line in using the farrel as it only crushes properly one time.
Jason C SBB
05-26-2005 02:57 PM
