No fuel pressure?!?
Old Mar 18, 2007 | 05:58 PM
Dat1BVtecN's Avatar
Default No fuel pressure?!?
just put my motor back together and everything and im gettin no fuel psi now. never ran to this problem, fuses are cool and everything is plugged in.
Old Mar 18, 2007 | 11:08 PM
Dat1BVtecN's Avatar
Default Re: No fuel pressure?!? (Dat1BVtecN)
bump
Old Mar 19, 2007 | 02:41 AM
senoj's Avatar
is the fuel pump priming? also check for leaks.
Old Mar 19, 2007 | 07:30 AM
Dat1BVtecN's Avatar
Default Re: No fuel pressure?!? (senoj)
ummm ok, anyways, fuel pump is no even starting and there are no leaks
Old Mar 19, 2007 | 06:44 PM
postman's Avatar
did you recently do any fuel pump work, maybe connected pressure and return lines backwards. if the pumps running and you have no pressure almost a gurantted bad pump especially of theirs no leaks. assuming you checked yhe pressure at the rail or filter
Old Mar 19, 2007 | 07:43 PM
Dat1BVtecN's Avatar
Default Re: No fuel pressure?!? (postman)
found the prob.
ejfromwestbay
Aug 18, 2010 05:44 PM
092eg6
Dec 11, 2009 01:36 PM
RedRocketCRX
Aug 23, 2004 01:50 PM
Lsos
Jan 16, 2003 11:56 AM
E Swift
Nov 4, 2002 07:55 PM
