emergency break question
i searched couldnt find anything.
anyways i have a 99 civic ex and im doing a rear disc conversition. do i need the si emergency break cable instead of the ex one?
Re: emergency break question (arizo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by arizo »</TD></TR><TR><TD CLASS="quote">i searched couldnt find anything.
anyways i have a 99 civic ex and im doing a rear disc conversition. do i need the si emergency break cable instead of the ex one?</TD></TR></TABLE>
yeah, any civic from 92-00 and integra 94-01 with rear disc brakes will do.
Yes because the 99 EX ebrake cable clips are different, they will only fit on drum brakes and not rear disc brakes.
Seagull Management
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by arizo »</TD></TR><TR><TD CLASS="quote">ok, got the cables from the honda dealership.
the si brake proportioning valve is necessary in the ex model?
or are they the same?</TD></TR></TABLE>
Its supposed to be the same across all 6th gen civics, but if you want to confirm just call your local honda dealer and have them cross reference the part numbers. if they match they're the same, if not theres a difference.
Seagull Management
Re: (arizo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by arizo »</TD></TR><TR><TD CLASS="quote">another question before i order my lca im using a 94 gsr trail arm on my 99 ex civic, but is it ok for me 2 use the LCA for a civic or integra? thanks</TD></TR></TABLE>
Use your civic LCAs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by arizo »</TD></TR><TR><TD CLASS="quote">the si brake proportioning valve is necessary in the ex model?
They are not the same, but swapping the PV is not necessarily necessary...
The SI PV is the same as for the Hatchback CX/DX: 46210-S04-902
The EX PV is: 46210-S04-962
... unless, of course, your EX is ABS...
JasonGhostz
JasonGhostz
94EG8: good looks
JasonGhostz: i heard that usuing the ex could cuz ur rear disc to lock up. thats y im trying to make sure but since the cx/dx and si pv have the same number it should be all good.
concidering this is a small project im taking my time with it.
If my trail arms are abs it wont matter right? and do i need to switch the caliper brake hose? (trail arm is off a gsr/my car is a 99 ex coupe)
Seagull Management
Re: (arizo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by arizo »</TD></TR><TR><TD CLASS="quote">If my trail arms are abs it wont matter right? and do i need to switch the caliper brake hose? (trail arm is off a gsr/my car is a 99 ex coupe)</TD></TR></TABLE>
It wont matter if your rear disc swap was off an ABS vehicle. You will need to swap the rubber flex hoses, the ones for rear disc brakes are different.
another question of the rubber hose http://www.napaonline.com/Mast...+Rear
is that what i need right?
Oki240ek9
02-11-2005 05:32 PM
Steak84SS
06-25-2004 07:12 AM
