EK people.. what brake lines to use for a 5 lug itr swap?
Old 08-12-2002, 11:36 AM
S2K2S's Avatar
Default EK people.. what brake lines to use for a 5 lug itr swap?
Can i use any integra lines 94+?
Old 08-12-2002, 12:13 PM
champITR's Avatar
Location: If ignorance is bliss... I am in the happiest, place on earth.
Default Re: EK people.. what brake lines to use for a 5 lug itr swap? (S2K2S)
lines should be indentical- the five lug swap only changes the hub/knuckle.
later
matt
Old 08-12-2002, 12:16 PM
S2K2S's Avatar
Default Re: EK people.. what brake lines to use for a 5 lug itr swap? (champITR)
thanks, so i can use my stock ek lines? or integra?
Old 08-12-2002, 12:19 PM
owen_the_soyboy's Avatar
ITR lines are a bit longer to reach the farther distance out to the caliper!
Old 08-12-2002, 12:34 PM
S2K2S's Avatar
Default Re: EK people.. what brake lines to use for a 5 lug itr swap? (owen_the_soyboy)
a little confused. what do you mean?
Old 08-12-2002, 12:37 PM
tonyxcom's Avatar
the rotors are bigger, so the caliper is farther out from the center of the hub. so the cables are slighly longer to reach them.
Old 08-12-2002, 12:41 PM
champITR's Avatar
Default Re: EK people.. what brake lines to use for a 5 lug itr swap? (tonyxcom)
I have done it using stock lines, they were not tight at all.
later
matt
Old 08-12-2002, 12:44 PM
S2K2S's Avatar
appreciate all the help and advices!
S2K2S's Avatar
Old 03-14-2004, 05:47 PM
ekin's Avatar
i have 5 lug but no e brake.. what should i do?? do i get some si link
Old 03-14-2004, 05:48 PM
Ricey McRicerton's Avatar
Default Re: EK people.. what brake lines to use for a 5 lug itr swap? (ekin)
ITR e-brake cables.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by champITR &raquo;</TD></TR><TR><TD CLASS="quote">I have done it using stock lines, they were not tight at all.
later
matt</TD></TR></TABLE>
Stock EK lines or stock Teg lines?
Old 03-14-2004, 06:33 PM
built562's Avatar
Default Re: EK people.. what brake lines to use for a 5 lug itr swap? (Ricey McRicerton)
all integra brake lines are the same. i have checked part numbers for 97 ITR and 94 GSR and guess what???
same brake lines
Old 03-14-2004, 07:32 PM
EricUSC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S2K2S &raquo;</TD></TR><TR><TD CLASS="quote">thanks, so i can use my stock ek lines? or integra?</TD></TR></TABLE>
I don't think the stock EK lines would work (unless you can modify them) because stock EK lines are for rear drums. Integra lines would work, but I heard they may be a bit long, but I'm not sure. I use 99-00 Civic Si lines for my 5 lug and they are a perfect fit. The 99-00 Si has rear disks, and the distance from the master cylinder to the calipers is exactly the same on the Si as it is in your car.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekin &raquo;</TD></TR><TR><TD CLASS="quote">i have 5 lug but no e brake.. what should i do?? do i get some si link</TD></TR></TABLE>
If your car came stock with drums, you will need new e-brake cables (unless you can modify them). I used Civic Si e-brake cables but ITR e-brake cables will also work and they are the exact same length as the Civic Si cable from what I can see. I have a set of barely used ITR e-brake cables. IM me if you're interested in a good deal.
Old 03-14-2004, 08:28 PM
frankdatank's Avatar
get steel braided lines
Old 03-14-2004, 08:32 PM
BI8B's Avatar
Default Re: (frankdatank)
i used 99-00 SI stainless steel brake lines on my 96 hatch with ITR conversion.
Old 03-14-2004, 08:36 PM
PariahBoardshop's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BI8B &raquo;</TD></TR><TR><TD CLASS="quote">i used 99-00 SI stainless steel brake lines on my 96 hatch with ITR conversion. </TD></TR></TABLE>
yeah get steel braided lines.. but up front at least you can use ek stock ek lines.. because a steel braided line busted on my car before and a stock ek line fit fine.. (i am 5 lug)
Old 03-15-2004, 03:14 PM
benhatch101's Avatar
be sure to post pics when your finished !
Old 03-15-2004, 04:10 PM
Derek14's Avatar
Default Re: (1FakeAssSI)
the stock lines are just fine... i just did mine about a weeks ago..... pics --&gt;&gt;&gt;https://honda-tech.com/zerothread?id=800324
Old 03-15-2004, 04:16 PM
JDM-97CX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by frankdatank &raquo;</TD></TR><TR><TD CLASS="quote">get steel braided lines</TD></TR></TABLE>
Thank you. Finaly someone said it. There is such a thing as better than OEM.
Old 03-15-2004, 04:17 PM
Default Re: (Derek14)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Derek14 &raquo;</TD></TR><TR><TD CLASS="quote">the stock lines are just fine... i just did mine about a weeks ago..... pics --&gt;&gt;&gt;https://honda-tech.com/zerothread?id=800324</TD></TR></TABLE>
He had a GSR setup before, so keep that in consideration. They were already Teg lines.
Old 03-21-2004, 12:26 PM
mor ber's Avatar
Default Re: (Ricey McRicerton)
I did it with stock EK lines. worked fine. I never did track day with the car though, only autocross twice.
edit: EK EX, i put the 99 si brakes on my CX and had to swap the rear lines. The front lines i didn't have to swap though.
Modified by mor ber at 5:32 PM 3/21/2004
Old 03-21-2004, 12:59 PM
miahmouse's Avatar
Default Re: (mor ber)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mor ber &raquo;</TD></TR><TR><TD CLASS="quote">I did it with stock EK lines. worked fine. I never did track day with the car though, only autocross twice.</TD></TR></TABLE>
so you went from rear drums to rear disk and you somehow managed to use the stock brake lines. please explain how you did this as they are completely different.
Old 04-01-2004, 12:37 PM
teg92's Avatar
Default Re: EK people.. what brake lines to use for a 5 lug itr swap? (akumaracer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by akumaracer &raquo;</TD></TR><TR><TD CLASS="quote">all integra brake lines are the same. i have checked part numbers for 97 ITR and 94 GSR and guess what???
same brake lines</TD></TR></TABLE>
Front are same part numbers, rear are different.
GSR:
01464-SR3-N03 HOSE SET, R. FR.
01465-SR3-N02 HOSE SET, L. FR.
01466-S04-900 HOSE SET, R. RR.
01468-S04-900 HOSE SET, L. RR.
ITR:
01466-S03-Z00 HOSE SET, R. RR.
01468-S03-Z00 HOSE SET, L. RR.
Old 04-01-2004, 09:29 PM
ricearoni56's Avatar
97 :thumbup gsr hb 5lug
Definately Steel Braided
Old 04-01-2004, 09:39 PM
epkaravan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekin &raquo;</TD></TR><TR><TD CLASS="quote">i have 5 lug but no e brake.. what should i do?? do i get some si link</TD></TR></TABLE>so u drive around without e brake?????????
forcefedsi
05-02-2009 10:31 PM
Steve-
10
09-08-2004 09:58 PM
ATS*Mark
10-21-2003 09:12 PM
EKen9
10
07-13-2002 10:37 PM
fowler!
05-24-2002 02:15 PM
Quick Reply: EK people.. what brake lines to use for a 5 lug itr swap?
