Which e-brake lines for 5 lug on EK?
I was wondering which e-brake lines are needed for 5 lug conversion. Can I use the stock ones or do I need Si ones?
Re: Which e-brake lines for 5 lug on EK? (EKen9)
I'm thinking the guy above misread and thought brake lines instead of ebrake. Anyways, if the swap comes with the ebrake cables from the teg then you can use those, you just have to unhook one mounting point, no big deal cause the way the cables are routed it can't fall off or snag anything. If it doesn't come with cables buy SI cables. Good luck.
Re: Which e-brake lines for 5 lug on EK? (C-man)
Yeah thanks for the help, i need ebrake lines. Do you guys know how much they run and what the part number is?
1 Post
You can use your stock front lines, but you're gonna need to use either civic si or the ITR lines in the back. You can always go to an Earls shop and have custom lines made for like, $25 each..
I did a rear disc conversion on my 96 civic and used si ebrake cables and u will also need si ebreake cable mounting brackets for the rear trailing arms.The brackets are about $12 each and u will need 2, the cables are about $60 for both.
Thrashin
11
08-15-2004 08:20 PM
S2K2S
24
04-01-2004 09:39 PM
ATS*Mark
10-21-2003 09:12 PM
