EG starting problems.
My girlfriend has a 92 EG, with the factory d15b7 in it automatic bone stock 150k miles. We are having some issues.
*fresh Plugs
*IACV cleaned
*Oil is fine
*Alternator is fine.
1.It would have erratic idle. from 1000-2000 rpms. Even so after cleaning. If you just tap the gas the erratic idle goes away. Backed the car up, ran fine.
I thought this was the only issue...I was wrong.
2.The car died about 500 feet past my house when I came to a stop. When I backed up the driveway car was fine.
3.The car has starting issues. If you try to turn it over the starter will just *click*. If you hit try about 5-6 time it will start. I also tried jumping it and same issue.
*fresh Plugs
*IACV cleaned
*Oil is fine
