Rough start!!!!!
Old Feb 7, 2009 | 05:20 AM
lyzer227's Avatar
Icon3 Rough start!!!!!
ok here is my problem everytime when the engine is cold lets say in the morning i go to start my car (EG coupe w/ 94 LS motor) and it takes a while to start. engine is cracking but no start when the car does start after so many cranks the car runs rough way below idle car sounds like it wants to turn off, lets say 300 rpm. then i try to give it gas when at low idle and the car shuts right off but if i leave it to idle low for a 2-3 min the car jumps to normal idle. this olny happens when the engine is cold if say i start my car and go some where turn the car off then get back in the car the it starts up fine. if anyone has any info it would really help. thanks!
Old Feb 7, 2009 | 06:14 AM
jdmjoka's Avatar
DB squad #282
Default Re: Rough start!!!!!
my old ls integra did that same **** and i could not figure it out for nothing i changed the iacv alot of stuff never figured it out keep me updated if u fix it!
Old Feb 7, 2009 | 06:15 AM
jdmjoka's Avatar
DB squad #282
must be something with ls motors my buddys eg does it do
Old Feb 7, 2009 | 06:19 AM
lyzer227's Avatar
hopefully its not the motor but i will keep you posted.
Old Feb 7, 2009 | 07:27 AM
StokelesS_g2's Avatar
Mine starts a little rough too, but not like that. whew.
I've narrowed down my search to a bad leaky fuel injector.
It's the only thing that seems to make sense.
Fuel pressure drops down a little faster than normal when car is shut off. (FP gauge)
Flooded cylinder(s) in the morning will be hard to start.
Bad spraying fuel injector(s) will cause bogging, and lower your cars performance.
Old Feb 7, 2009 | 12:35 PM
lyzer227's Avatar
but would it do that if it is only the injector cuz it only does it when i start it cold it does idle a little high like at 1200 when it is cool so i will check out my injectors and i will post up what happens thanks
Old Feb 7, 2009 | 12:42 PM
lyzer227's Avatar
you know what would be cool if i had the specs for the sensors if anyone has them post it up here.
Old Feb 7, 2009 | 12:44 PM
lyzer227's Avatar
fuel pump, injectors, tps, iacv, etc. anything would help thanks
Old Feb 7, 2009 | 06:29 PM
lyzer227's Avatar
yeah the injectors are good i was wondering if the IACV could be the cause but i need the specs for it i know the TPS is good .4 closed and 4.5 WOT do you guys think it might be the fuel pump?
Old Feb 8, 2009 | 09:19 AM
artin01's Avatar
This might sound weird but change your spark plugs if your spark plugs are not good that’s what exactly happens specially in a cold weather. it happen to me before.
Old Feb 8, 2009 | 05:52 PM
lyzer227's Avatar
Originally Posted by artin01
this might sound weird but change your spark plugs if your spark plugs are not good that’s what exactly happens specially in a cold weather. It happen to me before.
well the sprak plugs are new and i have insected them and they r good.
Old Feb 9, 2009 | 06:50 AM
How did you test your injectors?
Old Feb 9, 2009 | 04:51 PM
lyzer227's Avatar
i tested the wiring with a noid light and the injectors i just checked the resistance on them cuz i found the specs and they are kool.
Old Sep 11, 2009 | 01:03 PM
calico2009's Avatar
New User
Hmm...because the prob was never "resolved" and it isn't clear what may have corrected it - I'm bringing this thread back!
So, I am having the same problems with my 93 integra. I go to start it in the morning and it's hard to start - takes a while. Then, once it starts it dies. If I let it warm up for about 10 min before taking off, it doesn't die. It does run poorly though (very shaky and seems like it will shut off, but doesn't). Also, the rpm gauge is all over the place and I hear a very faint whining sound.
I've done some research and read the Hanes manual and I'm considering:
Faulty fuel pump / relay
Ignitor?
Ignition Coil
Any suggestions??
Thanks so much!
greenlsvtech
May 5, 2009 03:36 PM
lyzer227
15
Feb 17, 2009 12:42 PM
lyzer227
Feb 7, 2009 12:02 PM
delguiner
Sep 25, 2004 01:45 PM
EK45VTi
Jul 30, 2004 03:40 AM
