eg rear trailing arm
can I use the trailing arm off of my drum brakes and put them on disc brakes?i heard it fits and it looks like it'll fit but i wanna be sure before I rip everything apart
thanks
thanks
Re: eg rear trailing arm (nighttrain33)
any sugestions on how to get then lose? i was planning on using my impact driver to get the star shapped ones loose
Re: eg rear trailing arm (yakitori)
How many times do I have to explain it?!? j/k
Get a torch and some WD-40 and you should be all set. Just WD-40 the bolt, then heat it with the torch, obviously being careful since the WD-40 is FLAMMABLE. Heat it for a good 30-45 seconds. Then try to get it off. It may take a couple of tries, but it has always worked for me. And try as much as you can not to break any of the bolts. I know that the trailing arm-to-suspension bolts are about $10 a piece.
-Shane
-Shane
cehcivic15
14
06-18-2012 12:50 PM
stripes777
08-11-2008 07:50 PM
. o 69 o .
17
04-04-2004 12:47 PM
If my back rear LCA bolts are seized up does that mean i have to get new bushings and break the bolt
Soda Popinski
03-30-2004 05:18 PM
