Question on rear coilover install
the rear bolts to take out on the lca aren't budging, i'm using at least 200 psi and a 300 lb ft trqe impact gun.. they turn about a quarter then stops and no movement beyond that? do u know y? what can i do to remove them, thanks asap..
well hopefully you dont have the same problem that i had on both my integras...the bolts had froze in the control arm bushings where i eventually broke the heads off the bolts where i then had to cut the control arms out and replace the bushings and get new bolts...
anyways just try the wd-40 and with the impact gun try goin back and forth tightening and loosing the bolt
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan GSR »</TD></TR><TR><TD CLASS="quote">HEAT
torch that sucka....
i've always found that a propane torch does wonders for stuck bolts</TD></TR></TABLE>
Not all the time
Not all the time
i have never took an impact to my car. I always use a breaker bar and slowly crack the bolt loose. go to the store and buy some PB blaster, soak then attack slowy, you dont want that impact to break the head off the bolt, then you will really be SOL.
cehcivic15
14
Jun 18, 2012 12:50 PM
