dx ecu for ls...
Re: dx ecu for ls... (dfwautowerks.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dfwautowerks.com »</TD></TR><TR><TD CLASS="quote">this is going to be my first swap with a ls engine. will the stock 94 dx ecu okay for now to run the ob2 ls engine? thanks </TD></TR></TABLE>
Yes for the time being...you will have to get a OBD1 to OBD conversion harness in order to run it though...you can find those on ecutuning.com...They are pretty cheap... good luck
Re: (dfwautowerks.com)
Yes that is what I mean...you will be fine running your LS on the PO6 (your ECU)....although if you plan on going with LS/VTEC later there are Three ECU's that you might as well buy and put in now....those being the chipped "P28" (92-95 civic Si/EX) , "PCT" (ITR/CTR) (you will need a OBD2 to OBD 1 conversion harness for this ECU) , or a chipped "P75" (96-00 Integra LS/GS) (you will also need the conversion harness for this ECU)
ted
01-06-2005 11:56 AM
WCI
11-13-2004 09:08 PM
