DOHC Del Sol A/C bracket and 99-00 Si A/C bracket the same?
Re: DOHC Del Sol A/C bracket and 99-00 Si A/C bracket the same? (yh23)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yh23 »</TD></TR><TR><TD CLASS="quote">DOHC Del Sol A/C bracket and 99-00 Si A/C bracket the same?</TD></TR></TABLE>
99-00 Civic Si OEM PN 38930-P30-000 BRACKET, COMPRESSOR
94-97 Del Sol VTEC OEM PN 38930-P54-000 BRACKET, COMPRESSOR
Re: DOHC Del Sol A/C bracket and 99-00 Si A/C bracket the same? (97civicdx)
there was a post that said you could use the del sol's or the si's...thats why i asked.
thx!!
thx!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yh23 »</TD></TR><TR><TD CLASS="quote">there was a post that said you could use the del sol's or the si's...thats why i asked.
thx!!</TD></TR></TABLE>
I believe it was the Si or CRV AC bracket
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97civicdx »</TD></TR><TR><TD CLASS="quote">If u searched, u could have found the answer.
Del Sol SI bracket is a p-54
99-00 SI is a P-30</TD></TR></TABLE>
Could someone please explain to me why other than the obvious honda stamped p-## difference? All Del Sol DOHC compressors are the same, and they are interchangable with the SI's, so are you saying the B16 changed?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DELSOLEMITE »</TD></TR><TR><TD CLASS="quote">
94-97 Del Sol VTEC OEM PN 38930-P54-000 BRACKET, COMPRESSOR </TD></TR></TABLE>
What is that supposed to mean?
Re: DOHC Del Sol A/C bracket and 99-00 Si A/C bracket the same? (speedfreek128)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedfreek128 »</TD></TR><TR><TD CLASS="quote">from what ive found out the 96 + Del Sol has the same as the 99-00 Si</TD></TR></TABLE>
so....it is the same then? or is the first guy right, and they are different ?
the diff in the a/c brackets is because a Del Sol w/ B16 uses a single cam compressor on the dual cam block while B18s have the dual cam compressor and mount.....the dual cam one mounts with no prob if u want to use a dual cam compressor
Fuster_Cluck
10
04-22-2005 10:46 PM
jdm jedi
09-14-2003 03:21 PM
J_SpeC_EK
03-20-2002 07:54 AM
