Do I have every thing for a JDM B16a into EG swap?
Please check to see if I have everything right please-
JDM B16a swap guide into EG civic
Mounting in the engine
1. Hasport mount kit
2. Rear engine bracket from 94 integra
3. Speedo drive unit from 92 civic
Drivetrain connections
1. Intermediate shaft from 1990-1993 integra
2. Left and right axles from 1990-1993 integra
Engine Management
1. PR3 or PWO ECU
2. Hasport cable to hydraulic conv.
Exhaust System
1. header from delsol vtec
Cooling
1. Upper and lower from delsol vtec
2. Thermostat housing from 94 integra
Shift linkage parts
1. Linkage and shifter from 94-up integra Gs-r
Other issues
1. DX 1992-95 MAP sensor (if you have a CX or VX)
2. Throttle cable from 1990-1993 integra
3. Obd1 injectors (from 92-95 DX, EX, or Si or 92-95 integra)
Is that all right? Do I need anything else that I may have missed?
Also, which models don’t have power steering and/or A/C (EX,SI,DX,CX, or VX)
Thank you
Engine Management
1. PR3 or PWO ECU
Exhaust System
Cooling
Shift linkage parts
Other issues
Thank you
Re: Do I have every thing for a JDM B16a into EG swap? (caliquick_teg)
i dont know what your trying to do but i have a b16a sirII motor and it just bolted in with the axels shift linkage and mounts i have a p30 jdm ecu and the wire harness is place racing
where did u get your swap or what r u trying to do?
what gen b16 is it?
what eg is cable trans?
what gen b16 is it?
Damn! You sure did some research before you asked! Looks good to me. I don't know exactly all the parts needed for the cable/hydro swap but the only thing I can see your missing is the Fuel line. 99-00 SI's have the correct banjo fittings for a b-series motor.We skimped that on my brothers swap but I got mine new at honda for like $30 and it's well worth it!
Good luck!
Good luck!
Is that an sir1 jdm b16a? If so:
You will also need an obd1 distributor.
What you are going to do about the engine wiring harness?
Either modify your stock harness
or
get an obd1 dohc vtec harness (gsr or del sol)
or
you need a special mounting kit and new mounts for this swap??
I thought the stock B16 mounts would work?
VX does not have power steering, the DX and CX came with it if they were automatics I believe.
[Modified by piscorpio, 8:15 PM 12/1/2002]
dx95civic
04-29-2020 08:03 PM
Skipphag da Devoura
26
02-21-2008 10:20 PM
