b20B Swap in a 1995 Civic Sedan EG
I have a 1995 civic 4 door sedan, i'm going to do a b20 swap and im just wondering if i have everything i need so far..
Engine:
- JDM B20B High Comp. Engine with P75 Head
- B16 Y21 5 Speed Tranny
- Intake Manifold & Throttle Body with IAVC & FITV from a 91 Integra
- Any Header from a B series
- Throttle Cable from 94 integra
- P75 Chipped/Tuned ECU with a b20b map
- Clutch & Flywheel from b series
- OBD1 Distributor
- OBD1 Alternator
- Power steering pump from 94 integra
- Shift Linkage from 94 integra
- Starter from 94 integra
Mounts / Axles:
- Rear T Bracket from 94 integra
- Motor Mounts kit for 94 integra
- Axles from 94 integra
- Half Shaft from 94 integra
- Front Transmission Torque Bracket Mount from 94 integra
My Questions.....
Does Everything look like its plug n play from the parts i have?
Im also wondering if i can use a 94 integra throttle cable on a 91 integra intake manifold?
Will a 91 integra b18 intake manifold Even Fit on my B20B ?
Thanks for reading!
Engine:
- OBD1 Distributor
- OBD1 Alternator
Mounts / Axles:
My Questions.....
Thanks for reading!
Re: b20B Swap in a 1995 Civic Sedan EG
Bump
Sorry to bump such an old thread but I am looking to do about pretty much the same thing. I am in the process of collecting parts I got pretty much everything. My main concerns are my obd2 sensors and such on my motor and my obd1 harness. Should i swap my oem intake mani for my b20b and get a obd1 b18 mani? Stuff like that.
