Missing something, doing compression test?
Old Sep 19, 2013 | 03:25 PM
jonyi27's Avatar
Default Missing something, doing compression test?
Did a compression test on my b20z2
compression should be 178psi minimum 135
28psi can be difference in between cylinders
ran car till all warmed up, took out 15 amp fuse for gas, and distributor connection...
Took all spark plugs out then put tester in 1,2,3,4 cylinders
had gad pedal to the floor turned it a couple times (did it alone) by the way
cylinder 1 - 135
cylinder 2 - 130
cylinder 3 - 128
cylinder 4 - 129
whyy?thats under the minimum not even one its all four,, just want to know what can cause this
Old Sep 19, 2013 | 03:43 PM
B_Swapped93's Avatar
Default Re: Missing something, doing compression test?
well they're all with in 5-7 psi of each other so I wouldn't worry too much engine is just old you can do a wet test also...
Old Sep 19, 2013 | 03:48 PM
jonyi27's Avatar
Yeah im doing a wet test tomorrow and see, hopefully my piston rings aren't toasted
Old Sep 20, 2013 | 07:11 PM
jonyi27's Avatar
Cylinder 1: dry, 135 ; wet 150
Cylinder 2: dry, 128; wet 148
Cylinder 3: dry, 135; wet 145
Cylinder 4:dry,130; wet 145
did test today, would I lose compression by having 2 breather filters? On valve cover and the nipple of the intake
Old Sep 20, 2013 | 07:26 PM
you can do it with the VC off and it won't make a difference. even tho that wouldn't be smart. imo the jump could have been worse the next thing you can do is a leakdown test but as I said earlier the engine is just old
Old Sep 20, 2013 | 10:17 PM
racebum's Avatar
gauge is off or you used an adapter tube on a gauge not designed for it
unless it's a positive seal gauge calibrated for it don't use those adapter tubes for DOHC engines, screw the hose direct. those tubes drop you random lbs of compression. 50-60-70lbs not unheard of
Old Sep 21, 2013 | 10:55 AM
Creator's Avatar
Not that it would make much difference, but make sure you doing the test with the throttle body open.
nate-b16turbo
Jun 7, 2015 10:51 AM
cnote308
Nov 11, 2013 04:17 AM
aznxpyroboi
Dec 9, 2007 10:09 PM
Tyteg
May 16, 2007 07:30 AM
Vanilla4215
Nov 7, 2002 09:46 PM
