D16z6 won't start please help!
Old 02-20-2007, 04:35 PM
eric2407's Avatar
Default D16z6 won't start please help!
The other day I was driving and the motor started to sputter. There was loss of power, sputtering and vibration. A buddy of mine told me that one of the spark plugs was mis-firing. So he told me to leave the car idling and remove one spark plug cable at a time to see which one was bad. I don't think it was a good idea because now it won't start. Cables and plugs are fine. I tried replacing the distributor but still no spark. Checked fuel pump and filter. Another friend of mine told me it could be the ECU. Can anyone help? I can't seem to figure this one out.
Old 02-20-2007, 05:26 PM
maynards_ek's Avatar
Default Re: D16z6 won't start please help! (eric2407)
It could be fouled plugs, bad wires, bad coil, tps, the list goes on. With this kind of problem you just have to start with the cheap stuff first and work your way up. Process of elimination.
Old 02-20-2007, 06:34 PM
MJ0LNIR's Avatar
Check the grounds
Old 02-20-2007, 06:38 PM
deadline's Avatar
Default Re: D16z6 won't start please help! (dr92cx)
time to change out the main relay..or check the fuel pump
Old 02-20-2007, 07:19 PM
theuntedstates's Avatar
like that other guy said, check your grounds. The one you should really be checking is attached to your thermostat housing. Its your ECU main ground and will kill your car in the manner you described if it is loose/corroded. don't throw parts at your car until you are out of troubleshooting options (never).
Old 02-21-2007, 07:21 AM
SlowIntegraLS's Avatar
Check your Spark plugs, wires and distributor. my d16zy wouldnt start due to bad plugs.
JAYDmManny1331
11-22-2009 09:33 PM
masterp
12-05-2006 02:26 PM
hmtcrxsir
11
11-28-2006 02:47 PM
stunt_driver
06-08-2005 04:55 AM
Quick Reply: D16z6 won't start please help!
