HELP HELP HELP HELP swapping d16z6 in to a VX
Old Jan 11, 2003 | 10:05 AM
Mitzu's Avatar
Default HELP HELP HELP HELP swapping d16z6 in to a VX
Since the engine harness from the VX is equipped with a five wire O2, will i have to use the harness from the d16z6 with the 4 wire O2...if i can use the VX harness how will i have to modify it......any input would be welcome...thanks
Old Jan 11, 2003 | 11:25 AM
buskethead's Avatar
Default Re: HELP HELP HELP HELP swapping d16z6 in to a VX (Mitzu)
On my vx, I used the engine harness and o2 sensor from the d16z6. I only had to change one wire for the o2 sensor to make it match up with the car's harness. I'm gonna try to find the post I made a while ago with all the info on which wire needs to be changed, so hopefully I won't have to write it again........
Old Jan 11, 2003 | 11:37 AM
buskethead's Avatar
Default Re: HELP HELP HELP HELP swapping d16z6 in to a VX (buskethead)
bleh, I can't find the post, but I just saw your other post too. So if you need me to show you what all is needed to use the d16z6 harness, just lemme know and I will write it up again. As far as using the VX harness goes, I am sure someone can help you with that, or you could buy a helms manual and you should be able to figure things out using all the wiring diagrams in there.
Randokuky
Sep 6, 2010 04:56 PM
90AccordVTEC
Oct 11, 2005 09:34 AM
slowbluhatch
Apr 12, 2005 07:43 AM
92hybridAccord
May 6, 2004 12:00 PM
Mitzu
Jan 11, 2003 10:56 PM
