D15B VTEC Engine - Which Timing Marks at Cam Gear Do you Use?
Former Moderator
So like the title asks, do you line the mark up to the pointer like you do on a D16Z6, or do you line up the two marks flat with the cylinder head deck like you would the D15B DX non-VTEC engines?
I need to know ASAP - I've got a customer's car right in front of me, and i'm not sure, so guesses are not what I need, thanks.
Former Moderator
Re: (mc)
Awesome.
So you line the marks up flat with the cylinder head just like the other 1.5L non-VTEC engines.
So I guess that means the only 92-95 D series engine that uses the one mark lined up with the pointer is the D16Z6 and 1.6L VTEC ZC.
Re: (B18C5-EH2)
There is actually 3 marks on the cam gear, two of them are parallel to the head and the one of the bottom left lines up with the pointer on the plastic behind the cam gear. Trust me i had a hard time too. my T belt jumped 4 teeth so i had to realign everything. Just look on the cam gear for the three marks and line the two parallel with the head and the third should line up with the mark on the plastic.
4DRmafia
08-14-2006 09:53 PM
