crank and camshaft timing question ??
i was puttin on the clutch and i couldnt tighten the bolts without having the crankshaft spin... so i put a steel rod in the sprocket for the camshaft so it wouldnt spinn... so i was tightening the clutch bolts ( the bolts that go directly into the cranshaft) and the crankshaft moved but the camshaft didnt... i dont see how this is possible since the timing belt has grooves in it.. im pretty sure it didnt jump teeth on the sprocket.. my question is.. what could have happened to make the crank spin but no the camshaft.. any input would help thanks
WalkerTexasRanger
09-07-2012 09:06 AM
HackeN
12-14-2005 04:56 PM
Si Shane
12-04-2004 06:10 PM
