compression???
compression???
I searched but to much arguing to make sense, so let me get this straight. to do a comp. test take the plug and wire out, take out the ecu fuse and every thing should be ok. please correct me if I'm wrong then crank 7 times on each cylinder to get an accurate reading? and does any one know what the #'s should be on a d16y8 stock, and a 94 civic ex stock?
Re: compression??? (darkwater_ghost)
The actual numbers aren't that important as long as they're above 120psi. Consistency between cylinders is what you're looking for. What were your numbers?
motegicivic
03-08-2012 05:13 AM
