How to do a compression test?
Old Mar 14, 2004 | 11:18 AM
danny98r's Avatar
Default how to do a compression test?
im about to go to the track soon and i want to know that my car is running right in all aspects. if i want to do a compression test on my own what would i have to do?
Old Mar 14, 2004 | 11:24 AM
.RJ's Avatar
.RJ
Default Re: how to do a compression test? (danny98r)
http://www.c-speedracing.com/h...t.php
Old Mar 14, 2004 | 04:37 PM
Crazzy's Gsr
Guest
Posts: n/a
yo bring ur car to me, i'll charge u 30 bucks to do it.. i live in ur town an d i work for honda..
Old Mar 14, 2004 | 04:49 PM
hype-ar's Avatar
yo im from elizabeth, i have a py Type-r i have a compression tester and will help u out let me know.
Old May 18, 2005 | 10:24 AM
BLUE EH3's Avatar
Help we my pennies
nj guys?
Old May 18, 2005 | 11:10 AM
PredatorGSR's Avatar
Default Re: how to do a compression test? (BLUE EH3)
Basically all you have to do is buy a compression tester from sears and plug it into each one of the spark plug holes one by one. Then you get the compression for each cylinder.
An instruction manual usually comes with the tester.
Mine cost 70 bucks i think.
Old May 18, 2005 | 12:17 PM
citrus3000psi's Avatar
Default Re: how to do a compression test? (PredatorGSR)
Pull the fuel pump fuse......
Old May 18, 2005 | 12:31 PM
Downey's Avatar
Default Re: how to do a compression test? (citrus3000psi)
tools you need:
Compression tester
Spark plug socket w/ extension
a friend (helps to have the extra hand to crank the car over)
dry test procedure:
1. pull the injector ground fuse/plug
2. unplug the distributor
3. remove all FOUR spark plugs
4. insert the compression tested into cylinder #1, crank engine over 5 times with the throttle plate wide open.
5. write down results, example: 195psi
6. repeat for other three cylinders.
7. maximum variance between cylinders should be no more than 20psi.
good luck!
DxBurnoutKing
May 11, 2013 01:02 AM
iHOPEyouCHOKE
Apr 27, 2006 04:44 PM
B18Redline
Dec 9, 2004 10:53 PM
BlackB18CTeg
Mar 24, 2003 08:44 PM
smslude
Feb 25, 2003 10:40 AM
