Compression #'s for B18B1
Old Jan 4, 2007 | 07:24 AM
one bad dx's Avatar
Default Compression #'s for B18B1
Hey whats up guys. Wondering if anybody could tell me the compression #'s for a stock B18B1. I've searched but cant find anything on it. Thanks.
Old Jan 4, 2007 | 07:37 AM
lVlemphizStylez's Avatar
Default Re: Compression #'s for B18B1 (one bad dx)
170ish to 199 is fine... If the motor is in decent shape youre probably going to fall into the high 180's low 190 range..
Old Jan 4, 2007 | 07:43 AM
ac_attak's Avatar
Also the numbers should be consistant.
Old Jan 4, 2007 | 07:59 AM
one bad dx's Avatar
Default Re: Compression #'s for B18B1 (ac_attak)
I know they should be consistent I just wasnt sure where they should be at all. I've always had cars with VTEC and those were always higher. Thanks for the input though.
Old Jan 4, 2007 | 08:35 AM
r126's Avatar
Are all compression testers created the same? What I mean is will a $50 compression tester will have the same accuracy of a $200+ tester?
What are some reliable brands?
Old Jan 4, 2007 | 09:55 AM
DC2 Mang's Avatar
Default Re: Compression #'s for B18B1 (rodal126)
all compression test will result differently
just make sure the car is very warm before you do the test, and pull your ecu fuse out before you perform the test to avoid spark and letting fuel enter the motor
as long as each cylinder is within 10% of eachother then you have no major problems
88 civic
Apr 5, 2009 03:21 PM
self_made
Jun 19, 2005 12:36 PM
sdinteg
Feb 1, 2005 07:52 PM
builtprelude
Jan 22, 2004 10:49 PM
