coilover system...
1 Post
coilover system...
i'm sick and tired of adjusting those koni reds...
it's hard to get the car levelled after adjustment...
and i'm a person on a budget... (i have $1500 saved up (in canadian $$))
i can't decide which ones to buy... what would be the best for under
$1500 in canadian?? I don't wanna get springs and shocks combination stuff...
i'm gonna try a different setup... any info or recommendation about
which setup to buy would be really appreciated.. thanks in advance...
Guest
Posts: n/a
Re: coilover system... (hoya_10fintec)
Shocks: http://www.grmotorsports.com/shockstech.html
Chassis tuning: http://www.grmotorsports.com/repent.html
Anti-roll bar tech: http://www.grmotorsports.com/swaybars.html
full coil-overs are expensive.
always been fond of the Intrak ARS.
1 Post
Re: coilover system... (YodaIsGod)
thanks!!
any more advices?? this might sound stupid but i was thinkin' about
those cheap Matrix full-coilovers... how do those work? anybody
have them on this board? OR how about HPracing full-coilovers? are they worth it??
thanks...
[Modified by hoya_10fintec, 6:27 AM 5/31/2002]
thanks...
Re: coilover system... (Stage:Tarmac EK)
Get a koni yellow and ground control combo. From what I heard the lower model of Teins the SS and HA don't have a good valve design.
1 Post
Re: coilover system... (underrated99si)
thank for good info guys
progress competition??... are they full coilover system? adjustable(stiffness)??
and how much do they go for?
Progress competition is a full coilover system. I believe there are dampening adjustments on the shock, I could be wrong though. They are rebuildable and you have options during rebuild to make the dampening effect stiffer. As for the spring rates on the Progress coilovers, I don't know offhand. The actual shock body is shorter than stock so I assume it'll give you a dropped height at even the highest setting.
Japanese coilovers like Tein, Zeal, BC etc..have a regular sized shock body so you can lower from stock height on down instead of having the car pre-dropped.
The G2 Racer
15
04-08-2004 05:04 PM
96hb
04-07-2004 09:22 PM
