Code 21: I am stuck.......
Old Apr 14, 2006 | 09:55 AM
asubennett's Avatar
Default Code 21: I am stuck.......
VTEC Spool Solenoid Valve,
I have great oil pressure, no oil leaks, everything is wired up correctly yet still I am throwing a code 21. VTEC spool solenoid. Any ideas. I have checked the o-rings around the solenoid itself. I am at a loss.
Old Apr 14, 2006 | 09:58 AM
IHaveTurbos's Avatar
Is it hitting VTEC? And what ECU is it?
Old Apr 14, 2006 | 10:02 AM
asubennett's Avatar
Default Re: (TurboElements.com)
Nope not hitting VTEC. It is a P28.
Old Apr 14, 2006 | 10:04 AM
Has it been Chipped or is it Stock? The ECU.
Old Apr 14, 2006 | 10:05 AM
asubennett's Avatar
It is socketed. But the wierd thing is initially all I had was a code 7 (TPS) and 14 (IACV) Fixed both of those and suddenly I have code 21. ???
Old Apr 14, 2006 | 10:06 AM
If there is no short it sounds like it could be a bad burn.
Old Apr 14, 2006 | 10:07 AM
asubennett's Avatar
I am leaning towards something mechanical almost now.
Old Apr 14, 2006 | 12:07 PM
N20civicB18's Avatar
Default Re: Code 21: I am stuck....... (asubennett)
swap out the vtec sol with one of ur buddys, see if it works?
Old Apr 14, 2006 | 12:15 PM
seen4ever's Avatar
Default Re: Code 21: I am stuck....... (N20civicB18)
how's your grounds?
Old Apr 14, 2006 | 12:27 PM
racinskittle's Avatar
Default Re: Code 21: I am stuck....... (seen4ever)
the jumper is cut right?
Old Apr 14, 2006 | 01:08 PM
asubennett's Avatar
Default Re: Code 21: I am stuck....... (racinskittle)
Ok, it was a loose pin on the plug into the ECU. Fixed.
Thanks guys for the ideas.
Old Apr 14, 2006 | 03:57 PM
nerdsports's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by asubennett &raquo;</TD></TR><TR><TD CLASS="quote">Ok, it was a loose pin on the plug into the ECU. Fixed.
Funny... I was gonna suggest you take a look at the wiring.
The same thing happened to me when I first put on the VTEC head and P28.
gotslicks
Nov 26, 2006 03:44 AM
gots_a_sol
Aug 4, 2004 05:32 PM
Mentat Ghola
May 15, 2003 10:15 PM
Hondasaurs
Apr 25, 2003 07:30 PM
EGh22aEG
Mar 18, 2002 04:18 PM
