code 9(#1CPS) after taking obd1 dizzy apart
Old 06-12-2013, 10:36 AM
B_Swapped93's Avatar
Default code 9(#1CPS) after taking obd1 dizzy apart
I did not remove the shaft just this thing circled maybe I put one of the wire clips/plugs wrong ?
that being said isn't the cps underneath the shaft/cover plate also code 20(happens all the time) is on to which in the past usually is because of a loose wire. it's on and off the code
Old 06-12-2013, 10:45 AM
n/a2boost's Avatar
Default Re: code 9(#1CPS) after taking obd1 dizzy apart
That is the crank position sensor. Did you put the wires back in like this?
Old 06-12-2013, 11:18 AM
the wire is sung ,am at school right now but will take it apart and wipe/clean thoroughly
update: drove the car around seems fine no sluggishness wiped around the cap+rotor reset ecu.
Old 06-12-2013, 06:21 PM
bump/update cel is off most of the time however when/if comes on no difference any ideas don't have time to clean the connections tonight
Old 06-13-2013, 01:06 PM
you can get the cell to go away if you turn the car off a few minutes into the drive but even when it's no bogging hesitation. what would it even do if it's bad
Old 06-14-2013, 12:41 PM
cleaned it and wiped the contact surface of the wheel and the sensor it's self re-set ECU all is good. surprised I didn't get more input....thx n/a2boost
Lucky-13
21
03-22-2007 05:27 AM
mightymaxgst
11-27-2006 10:28 AM
k9n
01-17-2006 02:50 PM
undefinedcrx
03-12-2004 01:11 AM
Quick Reply: code 9(#1CPS) after taking obd1 dizzy apart
