Crank Angle Sensor
Old Jan 16, 2006 | 08:38 PM
k9n's Avatar
k9n
Default Crank Angle Sensor
Okay, getting code 4 along with code 14 on a 95 Integra w/ LS-VTEC swap. Put working dizzy, no luck-put working dizzy in w/ working ECU, no luck. I pushed in all the wires on the ecu connectors/dizzy connectors and also put electrical tape where a couple of wires were cracked. Car worked for about 15min (meaning ability to rev. past 3500 rpms), then stopped and threw code 14 again. I cut the orange wire off the dizzy (before the connector) and spliced in a fresh wire to the orange wire on the other side of the connector. Car worked for 10 minutes until I turned it off and then back on. So now I am semi-out of ideas and have some questions:
1. Is it normal that when the car throws code 4 and stops me from revving past 3500 rpms, i can downshift and my new rpms will be higher than 3500rpms?
2. I am aware that in the helms u test alot of things with the orange CAS wire and a white wire...are there any other wires that could be the culprit.
3. Would it be possible to wire the orange wire directly to the ecu pin?
Any other ideas? Thanks a bunch!
Old Jan 17, 2006 | 02:50 PM
k9n's Avatar
k9n
bump!
rollinswapshop
25
Jul 31, 2011 02:42 PM
noender
Dec 5, 2010 12:08 PM
91ed9
Apr 19, 2007 05:23 PM
