wtf is a code 9 (obd1)
Old Nov 10, 2006 | 07:01 PM
mightymaxgst's Avatar
Default wtf is a code 9 (obd1)
hey i got a 94 gsr swapped eg and today it threw a code 9 (cylinder sensor) lol wtf is that??? the car doesnt run any different, but i want to fix it.
Old Nov 11, 2006 | 07:57 AM
Default Re: wtf is a code 9 (mightymaxgst)
Old Nov 11, 2006 | 10:40 AM
Fat Chick Magnet's Avatar
code #9=cylinder sensor. its inside your distributor. you need to replace your distributor with a new one. mine threw code 9 for 5 months straight until i replaced the whole dizzy.
Old Nov 15, 2006 | 03:07 PM
bks84's Avatar
Loved
also check the wiring. in my case the wire for that particular sensor came out of the harness. thus throwing that code. i plugged the little wire in and reset my ECU and it went away.
Old Nov 25, 2006 | 04:28 PM
N_A_is_best's Avatar
Default Re: (4sd4dr)
can u take a picture of the wire and or what color was it im having the same issue
Old Nov 25, 2006 | 05:00 PM
Default Re: (N_A_is_best)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by N_A_is_best &raquo;</TD></TR><TR><TD CLASS="quote">can u take a picture of the wire and or what color was it im having the same issue</TD></TR></TABLE>
code #9 is crank sensor inside the distributor. you need to replace it with a new one. usually with code #9 your car idles wierd and bogs a lot.
Old Nov 27, 2006 | 10:28 AM
Default Re: (dc2rtek)
the car runs perfect and its a brand new distributer from distributer king
Psyotik123
May 3, 2009 10:59 AM
caymanjdm97dc2
Jan 26, 2007 04:47 PM
eg_gsr11
Dec 1, 2005 06:18 AM
GuyInASpeedo
Sep 25, 2003 07:05 PM
wuhungsixxx
Oct 24, 2001 10:20 AM
