Clutch Squeaking
Clutch Squeaking
Today i noticed my cluth kind of squeaks when i press it even when the car is turned off??? what could this be??? Clutch time??? Bad tranny???
Re: Clutch Squeaking (Boost Pressure)
is it coming from your tranny or the petal. your cluch master cylinder may be worn out. Mine squeeks and leaks fluid but it still works. Maybe one day i'll fix it.
Re: Clutch Squeaking (mantic6t9)
I can hear it by the pedal but more like by the tranny. Im gonna go and have it checked tomorrow. How muhc is a Master Cylinder for a 96 HX??
New User
Mine does the same thing. But it still goes into gear, so I really don't care if it's broken or not. . . Clutch master cylinders are cheap.
Re: Clutch Squeaking (martilafox)
Mine works fine I was just trying to find out what the problem was incase itw as somethings erious i could start saving up.
Not sure, but I've heard squeaking comes from a broken counter-spring on the clutch pedal assembly... Apparently the pedal becomes harder to press.
When I bought my car, it was already like this so not sure how true it is.
Look under your dash at your cluch master cylinder and check for fluid coming from around the rod if there is fluid the seals are bad.
if thats fine...I wouldn't worry about it too much...doesn't sound serious.
Actually, mine does the same thing. It started to do it when i changed the fluid from stock ones to Motul RBF. But i noticed it's coming from the piston that attaches to the tranny (the cylinder that pushes out everytime you step on the clutch). But it works perfectly.....no leaks, nothing. Gets into gear fine.
blacklsvtec24
04-03-2008 12:04 PM
getupoffthatthan
35
12-24-2007 02:23 PM
JDMTurboCivic11
01-12-2006 05:10 PM
