clutch problemo...help porfavor ....
ight so while im driving...i get to a stop sign...after i "stop" i hold down the clutch put the car in gear and klahdfhsdaljhfjhsdf is all i hear...the car wont go into ne gears...but if i put it in a gear first then start it, it runs fine. once i let go of the clutch i hear oihawelkrfjlksaejfklsaehjf agian...btw im using a act stage 2 clutch 6 puck on si tranny with ls-v ne ideas?
Re: clutch problemo...help porfavor .... (hitvtecgetloud09)
Sounds like your clutch isn't disengaging. When did this start, after you changed clutches or messed with the hydro lines to the tranny?
I'd try bleeding them again - fill up resevoir, pump the pedal to the floor slowly 4-5 times, go release the petcock on the slave cyl, when it slows the squirting seal it again, repeat till the clutch is fine.
Re: clutch problemo...help porfavor .... (HiProfile)
well... after i did my swap...on idle my clutch would make a hissing noise untill i would hold the pedal down...and just last nite it gave out on me...and every time i press the clutch pedal down it makes a noise like somehting is breaking.
you could very well have a defective pressure plate. Take off the boot and take a peek in there once to see whats going on.
