civic camber question
Ok, im looking at either http://www.spcperformance.com/....html or http://www.spcperformance.com/....html camber kits from spc..
my question is, how much does camber usually change for every 1" that you lower your car? Does camber go (-) say 1 degrees for every inch? therefore w/ a 3" drop you would have 3degrees of (-) camber?
Solbros Owns Me
Re: civic camber question (Bad-T)
a 3 inch drop all around will probably give you somewhere between -1.5* and
-2.5* camber up front and probably between -.8 and -1.5 in the rear. It will depend with condition of currect components, etc
Re: civic camber question (Emerika)
thanks, but im not actually lowering the car 3"... Im trying to figure out the trend. The car will be lowered about 2" so I am trying to figure out what to set the camber at so that when when the front lifts about an inch under acceleration it will have 0 camber.
