civic with b18b will not start
Ok so the problem is a changed my clutch and flywheel and took the motor out so it would be easier and i could paint my engine bay. Anyway i put the everything together and my car cranks and cranks but wont start. I have spark, fuel all the way to the injectors, main relay is fine, fuel pump primes all dash lights that are supposed to come on do. brand new battery new plugs i have full power for everything else but the car wont just start up. its really annoying and it just makes no sense i have everything i neeed to get it started and it wont. does anyone know y this is? all the fuses are good and all the cranks are strong as hell any other ideas please give me anymore ideas
Re: civic with b18b will not start (95GSRBOI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95GSRBOI »</TD></TR><TR><TD CLASS="quote">You sure it's cranking... Ground wire from starter to ground</TD></TR></TABLE>
I was gonna say the same thing, Check your grounds first before anything, If its cranking over and everythings working it MIGHT be due to the ground from the starter..
1 Post
Re: civic with b18b will not start (Hiii Im TYLER)
ground check is a must the termo grund.and the passenger ground to tranny is must.
after that chen you injectors. and that all i got for you.
also this happened to my today... and my dizzy black whire from the two wire plug had got spliced.
eesupra420
13
08-11-2011 07:12 PM
