CEL code. Eg throwing a A/T code when its a 5spd. Help
Old Nov 18, 2008 | 12:10 PM
z6htch's Avatar
Default CEL code. Eg throwing a A/T code when its a 5spd. Help
Okay some help here. I checked my cel's and either I'm throwing a code 29 ( which to my knowledge there isn't such) or a code 10 and 19....
I know what ten is, but my car is a manual and its thowing a auto lock up control solenoid valve code, which is 19.
Any advice? I'm confused
Old Nov 18, 2008 | 12:13 PM
Nbboy7's Avatar
auto ecu
Old Nov 18, 2008 | 12:18 PM
z6htch's Avatar
Really? How do you know if you have one?
Old Nov 18, 2008 | 12:22 PM
Nbboy7's Avatar
take a pic of the inside or read the code on the side of the ecu
Old Nov 18, 2008 | 12:34 PM
z6htch's Avatar
I can't cuz the car isn't here but I can tomorrow around this time. Hmmm that would make since though cuz its a z6 swap from a 95 ex and the tranny is from a si. Thats probably why the guy switched tranny's was cuz the one on the z6 was a auto.
Old Nov 18, 2008 | 03:54 PM
daluv's Avatar
Was the car originally an automatic? The manual SI tranny (and motor) are the same as the EX manual tranny (and motor.) This sounds like either the ECU is from an auto, or the car was converted to manual but the previous owner never swapped the auto ECU for a manual ECU out of convienience (since he already they it.)
Old Nov 19, 2008 | 03:15 AM
z6htch's Avatar
I don't think so b/c don't you have to modify alot of things to convert it? And I'll check to see if its a auto ecu today, thanks guys!
Old Nov 19, 2008 | 02:24 PM
daluv's Avatar
Its not really a lot of stuff to do, a few wires, the pedal setup, and a mount. If the previous owner swapped the EX tranny for an SI one thinking they were going to benifit from it, they were very wrong because the SI and EX trannys are the same.
Old Nov 19, 2008 | 02:30 PM
z6htch's Avatar
But it had the original cluster that didn't have the light tree that tells what gear your in.. Therefore the car had to of been manual. I'm guessing he took the motor from a ex civic w/ a auto tranny and the ecu, and took a si/ ex manual tranny from another car.
Old Nov 20, 2008 | 12:37 PM
daluv's Avatar
If thats the case then definatley swap out that ecu with one from a manual car and give it a shot.
Old Nov 20, 2008 | 01:37 PM
sageuvagony's Avatar
To convert my auto ecu to manual ecu, it took about 5 minutes. It is extremely easy if you now how to use a soldering iron a bit. I'll post the link to the guide if I can find it.
Old Nov 20, 2008 | 06:29 PM
z6htch's Avatar
Anyone got that link. Don't have a soldering gun, but I'm sure I can do it as long as the instructions are simple. w/ pics lol.
Old Nov 21, 2008 | 09:50 AM
obuhmyuh's Avatar
jump rp13 on the circuit board
Old Nov 25, 2008 | 02:44 AM
Cuda's Avatar
man i had ths problem in my old coupe before... never figured out the problem..
the ecu was a manual...
evo500
13
May 25, 2010 11:10 AM
95musubi
Mar 28, 2010 08:08 AM
E36 Guy
Jan 17, 2006 07:41 PM
your username here
Nov 29, 2003 04:58 PM
JChops
Oct 9, 2003 06:53 PM
