difference between manual and auto ecu's?
Re: difference between manual and auto ecu's? (your username here)
I believe it will throw a code. Automatics have more sensors for the ecu to read than a car with a manual trans.
If I'm wrong someone please correct me.
Re: difference between manual and auto ecu's? (solsteeler)
I'm running an auto ecu(p75) in my manual EG with b18b. No code whatsoever. Only problem that I could really feel is that the redline comes in sooner for an auto ecu.
Hope that helps!
Hope that helps!
Re: difference between manual and auto ecu's? (SimpleFunction)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SimpleFunction »</TD></TR><TR><TD CLASS="quote">I'm running an auto ecu(p75) in my manual EG with b18b. No code whatsoever. Only problem that I could really feel is that the redline comes in sooner for an auto ecu.
Hope that helps!</TD></TR></TABLE>
you cannot run an auto ecu in a manual car without it pulling a code for the automatic lock up solenoid which is code 19. You must have a manual ecu
Re: difference between manual and auto ecu's? (salbaje)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by salbaje »</TD></TR><TR><TD CLASS="quote">
you cannot run an auto ecu in a manual car without it pulling a code for the automatic lock up solenoid which is code 19. You must have a manual ecu</TD></TR></TABLE>
Im not picking up any code at all with an auto ecu. It's possible.
cuts
03-12-2010 05:11 PM
E36 Guy
01-17-2006 07:41 PM
