CEL 22 - VTEC pressure valve? need help!
Old Mar 26, 2006 | 06:28 PM
f2m0u5's Avatar
Default CEL 22 - VTEC pressure valve? need help!
FIXED PROBLEM
I got this CEL and dont know what it means. Ive been told it means low oil or bad vtec solenoid.. can somebody help me out?? I just barely swapped this motor in, bought it from PASSWORDJDM so I'm hoping its not a bad vtec solenoid.
specs:
99 EK
95 JDM GSR swap*stock
P30 ecu*I know I need a p72 but this is all i got for now
OBD2B to OBD1 conversion harness
Modified by 0LlY at 1:32 PM 3/27/2006
Old Mar 26, 2006 | 08:44 PM
sc4dr's Avatar
Default Re: CEL 22 - VTEC pressure valve? need help! (0LlY)
Vtec solenoid's are not expensive, and there easy to replace. That's probably your problem, unless your wiring has a short in it somewhere in between your ecu and the vtec switch.
Old Mar 26, 2006 | 09:06 PM
f2m0u5's Avatar
Default Re: CEL 22 - VTEC pressure valve? need help! (sc4dr)
I think it might be my wiring also if my switch or solenoid hasnt gone wrong, I'm going to try to check tomorrow
Critikul
Mar 1, 2012 05:54 AM
dave181
11
May 26, 2009 03:49 PM
f2m0u5
Apr 13, 2006 08:32 PM
f2m0u5
11
Mar 26, 2006 11:43 PM
lshatch1.8
10
Nov 28, 2005 08:51 AM
