Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine and Powertrain
- Honda: How to replace battery
Step by step instructions for do-it-yourself repairs.
car won't start after replacing battery ?
replaced battery in my car and my car won't even turn over. all that works are the hazards. should i check all the fuses. what am i missing i can't be this retarded.
Re: car won't start after replacing battery ? (UnrealSpeed)
battery is fine cause i tested it. before i put the battery everything was dead but now only my four ways work. i won't get a click, noise or a beep from anything. how is this possible. checked wires everything seems to be ok. (just for some background my other battery died because i left my lights on all day ) someone give me a idea or atleast tell me i'm dump
Re: car won't start after replacing battery ? (vizsual00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vizsual00 »</TD></TR><TR><TD CLASS="quote">battery is fine cause i tested it. before i put the battery everything was dead but now only my four ways work. i won't get a click, noise or a beep from anything. how is this possible. checked wires everything seems to be ok. (just for some background my other battery died because i left my lights on all day ) someone give me a idea or atleast tell me i'm dump </TD></TR></TABLE>
check fuses...
try to jump it...
check fuses...
try to jump it...
Re: car won't start after replacing battery ? (degooser)
might have found the problem. my 80A battery fuse looks f'ed up. didn't know leaving HID's on could do that . oh well. will replace and see if thats the only problem. thanx for help
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vizsual00 »</TD></TR><TR><TD CLASS="quote">might have found the problem. my 80A battery fuse looks f'ed up. didn't know leaving HID's on could do that . oh well. will replace and see if thats the only problem. thanx for help </TD></TR></TABLE>
I was going to suggest you check the fuses again. I had the same exact problem and it was the fuses(I think I checked them like 3 times before I finally found it).
Junkyard Dogg
05-07-2006 05:34 PM
MooreBoost
08-31-2005 08:53 PM
