Car Wont start
Car Wont start
My sister has a 99 Civic and it wont start. When it started happening I would turn the key and all you would here was aclick and nothing cranking. So with me hearing that i thought it was the starter.Got a new starter installed it and it still wont start and doesnt click no more...Now i checked all the fuses and they are all fine...Help...my sis needs her car back..Thanks
Re: Car Wont start (EggRollzEveryDay)
It would be worth testing the alternator too. Then you know the battery is getting charged. If you jump start it be sure and connect the Neg cable to a ground point on your engine block and not your battery Neg post....else you can fry alternator components ! ...... although thats the standard procedure for jumpstarts on any car to avoid spark- KABOOM at battery...
well if your battery is completely dead, jumping wont work sometimes. swap out batteries, or charge it up and see if anything happens.
make sure u check the 80w battery fuse under the hood its a big black fuse wit a clear top. If its blown try conecting the 2 screws underneath it with some speaker wire. If it works make sure u dont leave the wire trust me
speedracer33
05-02-2005 08:57 AM
