Car Shaking
Cigarette Squad
Car Shaking
1994 Civic Hatch Manual--
Alright everytime i sit at stop lights or w.e ill put it in netural and it just shakes, not a weak shake either like everything in the car is shaking. Seems to be getting worse now so seeing if anyone would know why
Cigarette Squad
Re: Car Shaking (boostedcivicsir)
nope..well its been really "boggy" put i think thats cause i need new o rings because im leaking oil and spitting oil out of exhaust
if you are spitting oil out the exhaust i doubt your compression is up to par, if it is though, the next most likely cause would be a fouled plug/s from the oil blowby.
Re: (McGeeTM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by McGeeTM »</TD></TR><TR><TD CLASS="quote">ok..so whys my car shaking so bad</TD></TR></TABLE>
check your mounts
hows your idle?
check your mounts
hows your idle?
dude, if you are spitting oil out the exhaust you have bad rings or valve stem seals, either way you are going to foul plugs like a mother causing incomplete combustion and a very very rough idle because the car will be running on less than all 4 cylinders. also check your plug wires one might have came loose.
