Oil ring replacement?
Old May 6, 2004 | 06:57 AM
98cwitr's Avatar
Default Oil ring replacement?
Anyone ever had this done?
My compression check yeilded (230, 220, 235, 240) but my car is burning oil pretty bad. How much should I pay to get the rings replaced?
Old May 6, 2004 | 07:01 AM
RTW DC2R's Avatar
Your search for burning oil returned 34 results.
Old May 6, 2004 | 07:03 AM
mstewar's Avatar
Default Re: Oil ring replacement? (98cwitr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98cwitr &raquo;</TD></TR><TR><TD CLASS="quote">Anyone ever had this done?
My compression check yeilded (230, 220, 235, 240) but my car is burning oil pretty bad. How much should I pay to get the rings replaced?</TD></TR></TABLE>
it will be expensive to have done.. compression looks fine..
define "pretty bad"..
Old May 6, 2004 | 09:38 AM
Chris's Avatar
Remove block, remove pistons, (bore?)hone, install new rings,
I payed $1000 for bal&bp with new bearings. I did all the removal and re-install when my oil rings went bad.
Old May 6, 2004 | 11:15 AM
98cwitr's Avatar
Default Re: Oil ring replacement? (mstewar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mstewar &raquo;</TD></TR><TR><TD CLASS="quote">
define "pretty bad"..</TD></TR></TABLE>
1 qt /1500miles
Old May 6, 2004 | 11:16 AM
98cwitr's Avatar
Default Re: (RTW DC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2 &raquo;</TD></TR><TR><TD CLASS="quote">Your search for burning oil returned 34 results.</TD></TR></TABLE>
true...but my thread is about oil ring replacement prices and recommendations
Old May 6, 2004 | 11:29 AM
RTW DC2R's Avatar
Default Re: (98cwitr)
true...but my thread is about oil ring replacement prices and recommendations</TD></TR></TABLE>
My post was to lead you into more problem determination before pulling the motor apart. Unless you are absolutely sure it is the rings causing the problem, or dont need to pay anyone to do the work, do some more PD.
Old May 6, 2004 | 11:38 AM
mstewar's Avatar
1 qt /1500miles</TD></TR></TABLE>
you sure it's not leaking from somewhere?
also, a lead-down test might be worthwhile.. would probably tell you for sure if your rings need replacing.. how many miles are on your R?
boostedh22lude1
Oct 24, 2007 02:01 AM
nekoabandoned
Jul 24, 2006 03:39 PM
mike93eh
21
Sep 18, 2005 12:23 PM
cgap
Jun 18, 2004 01:15 AM
salt
May 10, 2003 05:54 AM
