Any of you guys have a non running cd player due to missing a ground behind the dash?
My cd player isnt working since putting my dash back on after taking the whole car apart for a rebuild. What ground did i miss back there that could be causing this, or rather what grounds are back there that i should check for? Thanks guys.
Re: Any of you guys have a non running cd player due to missing a ground behind the dash? (Matador)
Hey. There is a ground near the steering wheel underneath near the center console be sure it's clipped on to the metal on the frame by the steering wheel . Also double check all of your harnesses. Good luck.
Re: Any of you guys have a non running cd player due to missing a ground behind the dash? (tabrisaka
Hey man! Thanks for the advice i'll make sure to look for it!
Nah that thing went haywire after a while. I tried to plug it up and blew the fuse. I know its a grounding problem cause when i touch a metal screw driver to the cd player and some metal it works.
I12BNU
14
11-06-2008 10:02 PM
NiCkArInO
08-21-2003 04:41 PM
