Car overheating!!!!!
I know I'm going to get some back lash for making another one of these... couldn't find n e thing that helped ...For starters i have a b16a in a eg hatch... The car runs fine; but overheats..... i have changed the thermostat checked to make sure the radiator isn't leaking. Changed the fan switch.... closed everything up and it still continues to overheat...... the top hose is hot the bottom is cold as if there is nothing in it... Im guessing it is because there is air in the hose.... which isn't allowing anit freezing to reach the brand new thermostat that i tested and replaced ( although other one was fine) therefor the t stat isnt heating up and opening as it should.... how do i bleed the bottom hose without a bleeder screw??? and yes i have sat there for like 30 min wit the car idling filling up the radiator even though its full so that way doesnt work????!!?!?!?! please need help
Shit Posts: 15
Re: Car overheating!!!!!
If you're adding fluid for 30 min
The HG is probably blown
And smoke from exhaust?
I've heard you can run the car with put a thermostat to bleed the bottom then once bled, re install the thermostat and re bleed
Not sure if that will work
