help car overheating
Old Mar 14, 2006 | 09:19 PM
Clutchmasta55
Guest
Posts: n/a
Default help car overheating
my car keeps on overheating
i changed the thermosat new coolent and even try bleeding it.
still keeps overheating after 15min of idle.
no leaks what so ever.
Old Mar 14, 2006 | 09:27 PM
solareclipseauto's Avatar
Default Re: help car overheating (Clutchmasta55)
your headgasket is probably going bad
Old Mar 14, 2006 | 09:30 PM
Clutchmasta55
Guest
Posts: n/a
Default Re: help car overheating (solareclipseauto)
brand new headgasket with resurface head.
Old Mar 15, 2006 | 01:08 AM
SiR Adam's Avatar
is the fan going on when it should?
Old Mar 15, 2006 | 09:41 AM
Clutchmasta55
Guest
Posts: n/a
Default Re: help car overheating (SiR Adam)
i have made a switch to the fan.
I turn it on when its warmed up.
Old Mar 15, 2006 | 09:42 AM
Clutchmasta55
Guest
Posts: n/a
i have a feeling its the cycle of the coolent. I think its not flowing right
Old Mar 15, 2006 | 09:43 AM
Clutchmasta55
Guest
Posts: n/a
tryed bleeding the coolent last night
but its funny because when I blasted the heater inside the car its not even hot air.
so i dont knoe
Old Mar 15, 2006 | 09:55 AM
NYCxTEG's Avatar
had the same problem.. make sure to check all ur hose for leaks.. even the little coolant hose that go to ur throttle body or to ur fire wall... also you could have a clog..........
Duster's Avatar
Heater core is shot? Maybe your radiator has had its day and its not cycling the coolant properly like you mentioned...If you just did new thermostat, and bled the system, and have a new headgasket thats theres not a lot left...
Old Mar 15, 2006 | 09:57 AM
yellowrexsi's Avatar
Default Re: help car overheating (Tegrasaur)
the new thermostat could even be bad. I have seen stranger things happen.
See if the upper and lower radiator hoses are the same temp.
Old Mar 15, 2006 | 12:10 PM
SiR Adam's Avatar
has the radiator ever been replaced?
Radiator cap..
Old Mar 16, 2006 | 04:27 PM
Clutchmasta55
Guest
Posts: n/a
problem been fixed
Old Mar 16, 2006 | 05:18 PM
Duster's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Clutchmasta55 &raquo;</TD></TR><TR><TD CLASS="quote">problem been fixed </TD></TR></TABLE>
What did you end up doing?
Old Mar 18, 2006 | 08:16 AM
Clutchmasta55
Guest
Posts: n/a
hoes were in the wrong spot
(not my car this is a friends car)
whoever have the same problem check ur hoes
Old Mar 18, 2006 | 08:57 AM
typerhedlights's Avatar
i got a similar problem. after my car being dorment for about 3 months (due to a bad tranny) i started it up and a **** load of white smoke came out and its definietly coolant cuz it has that distinct smell. i checked the radiator and it was low so i filled it up. my question is it didnt stop smoking after being at operating temp, could it be a blown head gasket or intake manifold gasket? the dipstick isnt milky and theres no sign of coolant around the oil cap. another thing i noticed is the lower hose to the thermo has no flow even after warming up meaning the thermostat stays closed. the top hose is hot as hell though. give me some insight guys thanks
Old Mar 18, 2006 | 09:50 AM
Default Re: help car overheating (typerhedlights)
bump
14psi
May 15, 2013 07:29 AM
JENNY_EG6
23
Nov 9, 2011 01:06 PM
vlude99
Jul 30, 2009 05:58 PM
eg:R
Oct 29, 2006 12:58 PM
hotinteggy
Sep 16, 2005 06:01 PM
